Hitec Electron 6 Receiver Antenna Cut
It got cut about 8 inches from the receiver in a bad accident.. so, can I just put it back together without issue?
Sachin |
RE: Hitec Electron 6 Receiver Antenna Cut
Just solder a connection between the two pieces and re-enforce the joint with heatshrink tubing. Not a problem.
