y-harness problems?
I have been trying to figure out why one of my aileron servos only moves in one dirrection. They are split with a JR y-harness that has some yellow shrinkwrap at the Y. It was working properly at the end of last season. The other servo works properly. Any suggestions? (batteries were charged)
RE: y-harness problems?
have you tried plugging a differant servo in it's place. it's probably the servo. the harness wouldn't do this
Try cycling the servo connectors in/out several times, often times low quality connectors corrode (especially tin plated), or buildup electrical resistance due to miss-matched connectors and or tarnish and the like.
I had same problem! Are JR connectors tin plated? Who makes better ones? Thanks Capt,n
