Li-Ion versus Li-Po on receviers and ignitions
Why is it that most big planes that I have saw lately are flying with Li-Ion batteries on the receiver and ignition. i thought that Li-Po's were the latest and greatest technology.
I guess the point that I am trying to get to here is why would you not just run Li-po's instead. What are the advantages and disadvantages of Li-Po's and Li-Ions on your recevier and ignition systems? Thanks for any advice.... |
RE: Li-Ion versus Li-Po on receviers and ignitions
Vibration and the fragile nature of the package in a high vibration enviroment Vs cylyndrical casing that is a bit more robust, but sacrificing higher current ratings.
I don't pretend to be a battery expert, but from the research I've done the Li-Ion is more stable and less likely to cause fires if slightly mis-handled or damaged than the Li-Poly. However the Li-Ion does not have the discharge rate capability of the Li-Poly which is why you find them in electric powered applications.
So I use Li-Ion for rx/ignition on my latest model and Li-Poly on my foamies which are the only electric powered stuff I have. There is a new chemistry of Lithium/Manganese coming out, although they are somewhat limited in sizes and availability right now, which has the promise of the discharge rates of Li-Poly without the hazards as it's not the volatile chemical combination of the Li-Poly's. Duralite has the new stuff, but not much information about them is posted; http://www.duralitebatteries.com/batteries-mg.html |
