JR XR3i TX and RX different brands?
I have a JR XR3i radio but only 1 reciever, i use that reciever for my Savage truck. Do i have to buy another JR reciever that matches the one i currently have to go into my boats or is just a matter of matching frequencies as I want to only have 1 controller around and not 1 for each model. Any ideas on another reciever that will work and wont break the bank as the reciever for the radio I have is expensive compared to most that I see around. Thanks
RE: JR XR3i TX and RX different brands?
Anyone? Please
I'm not a car/truck guy, but Hitec makes some cost effective airplane receivers compatible with JR equipment, so I'll bet they have surface stuff that would work for you, too.
Just make sure that the "shift" (which way the frequency is pulled by the modulation) is the same. JR airborne stuff uses a positive shift, while Futaba is negative. Hitec makes receivers that work with one or the other, and they also make some that are automatic shift select, so they'll work with just about anyone's FM transmitter. A quick look at the Hitec website confirmed that they do indeed make some FM receivers that would work with your JR equipment.. www.hitecrcd.com and no, I don't work for hitec - I just use their stuff in some of my planes with good success. |
Awesome, thanks for the help. Ill be looking into the Hitec stuff asap.
Thanks again |
