Killing the CCPM in a Blade CP radio?
I've come across a trashed Blade CP - gave $5 for it.
All I want out of it is the radio gear and servos to use in a el'cheapo foamie. How do I get rid of the CCPM mixing in the TX so that it can be used in a fixed wing? Since I'm not finding any internal switches (dimms or otherwise) I'd like to know if there is any sort of programming-type procedure to nix the mix? Thanks |
RE: Killing the CCPM in a Blade CP radio?
Anyone?
Nothing that I know of..
If you have a Futaba FM Tx you can swap a Futaba short single conversion crystal into the blade Rx and it'll work. |
I do have a old (still working fine) Futaba T6XA radio...
Its set-up for another foamie though. If I understand you right, I can run the Blades rx and servos with my Futaba if I put a single conversion crystal into the rx, right? No matter what, the Blades tx is pretty much useless for flying a fixed wing? |
Yeah.. this is the one here
http://www2.towerhobbies.com/cgi-bin...I=LXBFL1**&P=7 I fly my Blade CP with a Futaba 7C Tx |
