Futaba 9C question
Will this transmitter run 4 aileron servos 2 elevator 1 rudder 1 throttle. Thanks in advance James :confused:
Futaba 9C question
Yes, I would do the following
1 Left Aileron 2 Elevator 3 Rudder 4 Throttle 5 Mix with 1 Left Aileron 6 Right Aileron 7 Mix with 6 Right Aileron 8 Ailevator Mix (Rudder) 9 if you have it (ignition off or choke) |
Futaba 9C question
So it will do this setup, great I am thinking about purchasing this transmitter. Thanks :D
Futaba 9C question
Yes, it will do it with 3 of the 5 programmable mixes.
