Confused about Mode 1 or 2
Hi,
Being a resurected newbie to RC and having assembled my ARTF Trainer. I am a bit confused about mode 1 or mode 2 controls. I have a HITEC Laser 6 TX and RX with 4 servo's installed. Now I appreciate that left controls on the TX control throtle and flying surface and right controls control 2 other flying surfaces. Being a bit fresh to this hobby, I also noticed on my TX that I have a AUX which resembles a volume control. Would I be wise to connect the servo on the RX to the channel that is controlled by this knob or is that a no no ?? Also, would anyone have any links to what the flying surfaces do, I may need to reverse my controls and would hate to use a tank of fuel trying to take off when I am actually trying to bury the plane into the tarmac/field :D Help appreciated ------------------------------------ Regards Michael |
Try the Beginner info at http://www.rcflightunlimited.com
That will tell you what you need. You'll se that if the throttle (with the rachet) is on the left it is Mode 2. You will not need the 5th and 6th channels for your trainer. Steve |
You REALLY need to make contact w/a proficient RC pilot, and get advice, and flight instruction from him/her. The most likely place to go is you local hobby shop, if you don't know anyone. Please do this before you even THINK about altering modes, or using aux. channels.
GOOD LUCK, Bill |
Originally posted by bill white You REALLY need to make contact w/a proficient RC pilot, and get advice, and flight instruction from him/her. The most likely place to go is you local hobby shop, if you don't know anyone. Please do this before you even THINK about altering modes, or using aux. channels. GOOD LUCK, Bill |
Normal mode 2 is setup like this:
Left stick has a ratchet on the vertical movement - this is used for throttle. Left stick horizontal movement is used for rudder. Right stick vertical movement is used for elevator. Right stick horizontal movement is used for ailerons. If I recall correctly, the difference between Mode 1 and Mode 2 is thae left and right sticks are exactly reversed. Most people in North America fly mode 2, so the radios are shipped with that configuration. The knob you mentioned is ussually used for flaps, which your trainer won't have. Since your radio is a 6 channel, you will also have another channel available, ussually a switch for retractable landing gear. |
Originally posted by strato911 Normal mode 2 is setup like this: Left stick has a ratchet on the vertical movement - this is used for throttle. Left stick horizontal movement is used for rudder. Right stick vertical movement is used for elevator. Right stick horizontal movement is used for ailerons. If I recall correctly, the difference between Mode 1 and Mode 2 is thae left and right sticks are exactly reversed. Most people in North America fly mode 2, so the radios are shipped with that configuration. Michael |
Originally posted by Bananaskin Thats correct, to be honest I prefer to use left habd for throtle and right for surfaces, makes more sense to me, than using a non ratcheted control for throtle Michael John |
Originally posted by Bananaskin Am going down to a local club on Saturday, however the chairman has stated that all their flyers fly mode 1, but I feel more comfortable with mode 2. Suppose it will be a learning curve, hopefully not a downward spiral ;) If you are new to the hobby, and do not have any experience a stick R/C radio. how can you be more comfortable with one mode over the other? Mode 1 has distinct advantages over Mode 2 in precision flying. The elevator and aileron are on different sticks which means you are less likely to move the elevator when pushing aileron or vice versa. Mode 2 OTOH is very easy to learn as you only have to concentrate on one hand instead of co-ordinating both hands while you are trying to make the model do what you want it to do. John |
Originally posted by Bananaskin Thats correct, to be honest I prefer to use left habd for throtle and right for surfaces, makes more sense to me, than using a non ratcheted control for throtle John |
Originally posted by JWN If you are new to the hobby, and do not have any experience a stick R/C radio. how can you be more comfortable with one mode over the other? Mode 2 OTOH is very easy to learn as you only have to concentrate on one hand instead of co-ordinating both hands while you are trying to make the model do what you want it to do. Confusingly, Michael |
Originally posted by JWN On a Mode 1 radio, the right hand stick is ratcheted for throttle and the left is not. The throttle is always ratcheted unless you were to go in and remove the ratchet and add the centering spring. John Regards, Michael |
If you're flying planes, leave it just like it is. If you're gonna fly a Helli leave it just like it is only remove the ratchet (it's annoying cause Helli's need constant throttle adjustment planes don't) You can switch mode 1/2 in the transmitter by opening up and reversing the wires for the pots connected to the vertical axis of both sticks, and swapping the throttle ratchet with the spring. It's entirely up to your preference.
Originally posted by JWN This is probably correct as Mode 1 is very popular everywhere except the U.S. Since you are in Ireland, I would be surprised if the other modelers in your area flew anything other than Mode 1. John I believe that mode 1 stems from the limitations experienced in the early days of r/c units (don't ask me why). I think it would be easier for a beginner to have roll and pitch on one stick (throttle usually stays in one place in the first few flights) rather than trying to co-ordinate the axis on two hands! A competent instructor should be easily able to handle a trainer, and instruct on it, in mode 2 even if he/she usually flies mode 1! |
Modes
Mode 1 RULES DownUnder guys! :p
But mode 2 flyers are OK by me, no discrimination here! As long as you fly, it's all OK! When learning however, you will as a matter of practicality need to use the mode your instructor uses. Keep 'em flying & have fun! fiery |
Re: Modes
Originally posted by fiery Mode 1 RULES DownUnder guys! :p When learning however, you will as a matter of practicality need to use the mode your instructor uses. Keep 'em flying & have fun! fiery |
Yes a buddy lead will allow you to "swap" modes. I've done it a few times as I (and pretty well everyone locally) fly Mode 2 but some of my friends from elsewhere in the country fly Mode 1. When I'm visiting, the buddy lead allows us to fly one anothers models in comfort.
Steve |
On both the Multiplex Cockpit MM and the new Royal Evo transmitters you chan change modes without affecting anything else on the transmitter or aeroplane. No muss, no fuss, no buddy cord :D
Originally posted by Lynx If you're flying planes, leave it just like it is. If you're gonna fly a Helli leave it just like it is only remove the ratchet (it's annoying cause Helli's need constant throttle adjustment planes don't) You can switch mode 1/2 in the transmitter by opening up and reversing the wires for the pots connected to the vertical axis of both sticks, and swapping the throttle ratchet with the spring. It's entirely up to your preference. John |
Originally posted by rorywquin I have lived and flown in both the UK and Holland and have yet to see a mode 1 flyer! IMHO Mode 2 seems to be the dominant setup over here ! I believe that mode 1 stems from the limitations experienced in the early days of r/c units (don't ask me why). I think it would be easier for a beginner to have roll and pitch on one stick (throttle usually stays in one place in the first few flights) rather than trying to co-ordinate the axis on two hands! A competent instructor should be easily able to handle a trainer, and instruct on it, in mode 2 even if he/she usually flies mode 1! John - Mode 2 forever! |
Mode one actually originated in the early two stick days because it was a natural for most who flew reeds. The aileron and rudder toggles were on the right and the elevator and throttle were on the left. Since the elevator and ailerons were and still are the most used controls, it was a much easier transition to proportional from reeds and toggle switches.
Actually as I remember it, the first proportional system to hit the market in the States was a single stick system using a three axis stick. The name was Space Control and I believe it hit about 1963 or 4. |
Originally posted by ec121k Actually as I remember it, the first proportional system to hit the market in the States was a single stick system using a three axis stick. The name was Space Control and I believe it hit about 1963 or 4. Michael |
Originally posted by rorywquin On both the Multiplex Cockpit MM and the new Royal Evo transmitters you chan change modes without affecting anything else on the transmitter or aeroplane. No muss, no fuss, no buddy co rd :D |
ALL RIGHT BANANASKIN!!! You must have been talking with my wife.
I do remember and I'm a grandfather but not that old yet! I was very young when I saw those first Space Control systems being flown by Norm Holland up in Syracuse, N.Y. and Pappy DeBolt. One of the guys (he's really old) in our area here in Lancaster, Pa. had one too. Those systems worked "kinda" they tell me but did have their problems. The airborne system was a "brick". (All in one housing except for the aileron servo.) I couldn't afford one being in 9th grade and not having the $600 or so that they cost. It was the very beginning of our present level of technology. That first system was Analog and it didn't take long for others to realize that digital was the way to go. ENOUGH!!! |
Originally posted by Nitroholic marvellous but I dont know if there in aus yet and how do they go about changing the friction or rachet and spring on the throttle |
Originally posted by rorywquin Good point - hadn't thought of that - however in the Cockpit and RE it is not at all difficult to change racheting / friction sides (possibly a 2 minute exercise.... turn 2 screws in and 2 others out, with the provided screwdriver). |
