RCU Forums
-   RC Radios, Transmitters, Receivers, Servos, gyros (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/)
-   -   tough one--JR TX/Airtronics RX ?? (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/568860-tough-one-jr-tx-airtronics-rx.html)
3drc tim 02-19-2003 02:33 AM
I do not know if anyone has had this issue before but here goes:
A friend gave me a 92768 dual conversion narrow band RX and I want to drive it with an JR 8103 TX. Can this be done? I know how to make the necessary electrical connections with polarity and signal. This is suppose to be a real quality RX, I just don't know if is high side of frequency or low or what? Any ideas? BTW, this entire rig is on channel 07.
Thanks, Tim
blkbird68 02-19-2003 03:16 AM
JR tx/Air Rx
yes you can drive any Airtronics FM PPM Rx with your JR...you cannot however drive Futaba Rx's Although if you had an airtronics computer radio you could drive both JR and Futaba PPM Rx's
3drc tim 02-19-2003 04:37 AM
tried it out
Thanks blkbird,
I changed the leads on a servo and a battery and it works fine. The best range check I could do in my basement is 25 yds and it did all of that. Thanks for your help.
