X9303 questions
Danny
Couple of questions re the X9303 2.4 xmitter 1) What is the basic differences between the Air and Heli versions 2) Does this radio support 2048 resolution with the 921 receiver Does the AR9100 receiver support 2048 resolution Thanks Bruce |
RE: X9303 questions
The heli has a slightly different switch arangement and a smooth throttle installed. The air version has a push button switch that the heli does not but the heli has a momentary toggle that can do the same jobs. Otherwise, they are the same. I fly airplanes with my heli version if that helps. Yes, it supports 2048 with the r921 but I'm not sure about the ar9100.
RE: X9303 questions
I'd bet for the extra bucks that it does.
