i need a huge servo
what is the biggest damn servo i can buy, 1/2 scale or bigger, and where can i look at one online, I'm having trouble finding a servo that has more than 275 torque for 4.8 volts, i need a lot more power
thanks |
i need a huge servo
i don't even care if it's for an airplane, just as long as i can hook it to my rx......running off of 12 v but patched into my rx would be ideal
thanks guys |
i need a huge servo
http://www.vantec.com/ssps105.htm
http://www.tonegawa-seiko.com/e_index.html http://www.tokyo-hobbies.com/tonegawa.html Big enough? ;) For the PS050, 350 oz in stall torque @ 4.8 VDC up to 690 oz in stall torque @ 8.4 VDC |
Give us a call!
Sir,
Give us a call at 620-221-0421. We have several new servos coming out in June that put out between 700 and 2,400 in-oz of torque. Our first model we are releasing uses an HS-805BB in our latest 4:1 gearbox with 32 pitch gears. At 6.0V it puts out 1,360 in-oz of torque with a transit speed of .56 sec. We also offer it in a 2:1 (680 in-oz, .28 sec) and an 8:1 (2,720 in-oz, 1.12 sec). We may be able to get one to you sooner. Thanks! ServoCity |
i need a huge servo
Originally posted by Joe Trinkley i don't even care if it's for an airplane, just as long as i can hook it to my rx......running off of 12 v but patched into my rx would be ideal thanks guys Make sure that the y-harness and the switch are at least 18-20 gauge. |
i need a huge servo
BTW, may I ask what are you using these for?
You might want to check out Radicalrc.com, he makes battery packs. He has them in all different capacities, tx and rx, and they are reasonibly priced. |
i need a huge servo
How about these from Tonegawa:
http://www.tokyo-hobbies.com/105.gif (click on image) Out of curiosity, I checked the price... That's one expensive servo!!! - $554.95 :boxing: Pilotsmoe - when powering servos above 6V, the reciever has it's own battery (4.8V), and only the Rx signal wire and ground are connected to the servo. Then, a seperate battery (let's say 12V) is connected to the servo's power connections. Tonegawa provides an interface cable. http://www.tokyo-hobbies.com/diagram.gif |
servo
i need a huge servo
Pilotsmoe - when powering servos above 6V, the reciever has it's own battery (4.8V), and only the Rx signal wire and ground are connected to the servo. Then, a seperate battery (let's say 12V) is connected to the servo's power connections. Tonegawa provides an interface cable. |
i need a huge servo
The SSPS-105 (which I was refering to at $554.95 for 90° rotation) is available up to 28 Volts! At 12V, it produces 27 Ft/lbs of torque! To put that in perspective, thats 5184 oz-in at 12 Volt.
Imagine what it does at 28 Volt !!! |
:eek: geez...the servo arm must be about a foot long on that thing....what is that bolted down with? 3/8 bolts or do ya need to weld it? :D
