trim steps on the 9C
Hi Ann Marie,
Could you explain how the trim step graduations works and how i speed them up and slow them down. The manual on the 9C is not real clear on how to do this. Thanks Mike |
Hi, Mike! If you have a question direct for me, please put it in the "ask me" thread or email me at work, OK? Thanks!
The larger you make the step the farther it will trim per click. So a trim set to 40 will move 40 times as far as the trim set to one. The default is 4 and that's a pretty common setting for most basic models. As described in the example on page 41, to double how far the trim moves per "click", turn the trim up on that channel from 4 to 8. To cut it in half, bring it down to 2, and so on. Does this help? or am i missing something in your question? Sincerely, Mrs. AnnMarie Cross Senior Manager, Proprietary Services and Support Great Planes Model Distributors [email protected] www.greatplanes.com www.bestrc.com NO AUTORESPONDER |
