Futaba 6XAS Transmitter Antena
I had the antena on my 6XAS TX pull out this evening. the plastic mount cracked. I repaired the mount with CA and 1/32 plywood. The white antena wire also pulled loose from the board. My rpoblem is I can not figure out where to solder the wire back on.I can not tell where on the board it goes. Can somone with this TX tell me where on the board this wire goes?
Thanks for any help, Jim |
RE: Futaba 6XAS Transmitter Antena
Problem resolved. I called Futaba service and they told me where on th board the wire goes.
Jim |
