RE: DX7 Fail safe
JR,
How fast are the lights supposed to flash ? The light on my rx's are flashing pretty quick but will not bind in preset mode. Andy |
RE: DX7 Fail safe
FWIW the preset sticks to extreme servo position type "fail/safe is really a bad news setup
UNLESS you need a spin down/spiral down setting for some reason. Back when the PCM's first came out , this approach was gone over ad nauseum. |
RE: DX7 Fail safe
Dick,
I think they were just setting them at extrems to see if it worked. Andy |
RE: DX7 Fail safe
Been at this (RC) a l-o-n-g time.
I have NEVER seen a failsafe save an airplane. Short of low throttle I consider all 'failsafes' as basically useless. I have seen them cause inconvenient crashes. I have seen them give a warning such as a trip to low throttle. But save an airplane through 'pre-sets' NEVER !! |
RE: DX7 Fail safe
I agree, and have always felt the same, but there is one exception where a programmable fail safe (other than throttle) would be desirable to me, and that is with my thermal glider. If I could program it to go into a gentle spiral (up elevator and some left rudder) then there would less risk of a total flyaway in the case of loss of RF link.
I plan on switching my 2M sailplane to an AR500 for next season, would be nice to have that ability. Pete |
RE: DX7 Fail safe
ORIGINAL: pilotpete2 I agree, and have always felt the same, but there is one exception where a programmable fail safe (other than throttle) would be desirable to me, and that is with my thermal glider. If I could program it to go into a gentle spiral (up elevator and some left rudder) then there would less risk of a total flyaway in the case of loss of RF link. I plan on switching my 2M sailplane to an AR500 for next season, would be nice to have that ability. Pete |
RE: DX7 Fail safe
ORIGINAL: dick Hanson [/quote] These 'High-Tech' approaches are taking RC out of the hands of the ordinary modeler. |
RE: DX7 Fail safe
Thenk kwew , thenk kew
vera mush |
RE: DX7 Fail safe
Did Elvis or Nixon just leave the building ?? [X(]
RE: DX7 Fail safe
AJsToyz:
Even though you just bought the receivers it could be that they are old stock. All of the receivers I bought with the Great 2.4 Giveaway had to be updated. During the Preset operation, the lights flash at the same rate as during the "normal" binding operation. FWIW; I used to set up fail safe to cause a snap roll to prevent a flyaway and hitting a lawyers wife. The one time I had a frequency conflict which sent the plane into failsafe, I could have flown the plane back for a landing had I not had to spend time regaining control between the snap rolls. I now use failsafe only on the throttle and/or ignition control to kill the engine. JD |
