Eclipse 7 Transmitter with Spectra
What do you guys think of this Transmitter ? Ever have problems with the Spectra module ?
Thanks Jim |
I had the Prism with the spectra module (same exact module) and never had any problems with it. I found, although, that I really didnt need all those channels and ended up with everything on the same channel. Our club is not that large that all of those options are necessary....it was more of a pain to remove the module, change the channel, and then replace it all of the time than it was worth for me. I didnt have a lot of different channels anyway...only 3....converting was a better option in my case.
Can ypu purchase the transmitter without the spectra on one channel ?
Jim |
sure can....I sent ya an email
I have both the Prism and the Eclipse, both with the Spectra module and use it a lot. I often help others check out their airborne radio equipment and both the Prism and Eclipse allow me to check out all major brands with either positive or negative shift. To me, this is a big advantage. It also gives me ulimited choice in selecting flight packs as it will drive all of them.
me too
I intentionally have all my planes on different crystals. I have seen too many guys take off with the wrong model selected and crash. I don't mind popping out the spectra and dialing in my crystal. I only have 3 planes so it's not that big of a pain anyway.
