RCU Forums
-   RC Radios, Transmitters, Receivers, Servos, gyros (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/)
-   -   Futaba T6XH D/R throttle? (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/9716249-futaba-t6xh-d-r-throttle.html)
x3heimmr 05-06-2010 10:27 PM
I have a Futaba T6XH that has something coupled to the throttle or vis a versa. When I use the elevator D/R, the throttle opens to make the engine rev higher at idle. How do I make this go away? The elevator rate does not change either. I have the low D/R set at 50%. When the elevator D/R switch is moved, nothing changes on the elevator, but the throttle moves. I bought it used with this plane so I don't know what all has been programmed into it. I have turned off all the mixing I can find. Help me please........
X3
MinnFlyer 05-07-2010 07:23 AM
RE: Futaba T6XH D/R throttle?
You could just reset the model and wipe everything clean, then start over. Might be a lot easier than trying to find one little bug
