Resistor watt question...
If a circuit needs a 4.7k ohm resistor rated at 1/4 watt, is it ok to use a 4.7k ohm resistor rated at 1/2 watt? I'm pretty sure it is but wanted clarification before frying an expensive circuit :)
Thanks! -Brian |
RE: Resistor watt question...
yes....but it will be bigger and maybe a micro oz. heavier....:)
