JR PCM 10SX II or 8103???
Hi, i actually have 2 options to purchase a JR PCM 10SX II or the famous 8103, so i write to know wich one is the best option. I like to fly helis and planes, so i dont know if in the pcm 10 you can fly both, in the 8103 this is perfectly posible. The 2 radios i understand can be upgraded to 2.4 by modules, but i dont know anything else, so i want help to choose the right radio. Thanks.
RE: JR PCM 10SX II or 8103???
There were AIR versions for airplanes, and HELI version for helicopters for the 10SXII. The 8103 will do AIR, HELI, and SAILPLANE.
The 8103 can fly airplanes helis and sailplanes regardless of the version. The differences were the switch locations are optimized for the particular setup. Not sure about the 10sx ii. If can check the plastic of the case all around the area of the screen. There was a problem with early versions getting brittle and cracking. Mine has that problem.
if the sxII is anything like the 10x id get it... http://www.eclipse.net/~mikel/10X/JR10X.gif
http://origin-images.rcuniverse.com/...859-0-4986.jpg |
