servo recommendation 1/4 sig cap
I have a 1/4 sig cap with a 180 saito 4 stroke I was thinking about putting Hitec 5625 Digital or standered hi torqe 3005 futaba servos. any other recommendations tx
Hitec 605's or 645's would work well and even better on 6 volts.
I have the same combo. I would recommend high torque metal gear servos. I was using 9202's which stripped (both ailerons) out after a half dozen flights. Boy was that hairy! Now running with 9451's.
Mike |
I would recommend that you try the new hitec digitals, 5475. I think they are about $35 each.
