hpi rs4 not shifting
I finished the break in and tuning on my rs4 3 evo+, now i'm trying to change the shift point. i fallowed the directions to adjust it by turning a screw and nothing changed, i went with a 90* turns at a time like stated and got the screw all the way out as far as it can go and the car will still not shift.
RE: hpi rs4 not shifting
ORIGINAL: bigdogkanicsar
are you sure it isn't launching in second gear?
the first thing i did was tighten it all the way down and backed off 90* at a time as stated by the manual and there was no change by the time i tuned it up all the way.
in the manual it should tell you how to install it new( as if you just replaced the 2 speed clutch ) i would try that and go from there, cuz i'm a little stumped
found the issue, it has 2 grub screws in there, there is only supposed to be 1, i removed the extra one and it works now.
ORIGINAL: chuckmfnnorris
glad you got it workin
with a hobby like this, i've seen it a lot of things wrong straight from the factory( needle settings, loose screws, unglued tires, etc...) and pretty much tear everything down when it enters my home even if it's new just to be sure.
quality control will never live up to my expectations so i just do it myself.
before i ran it i checked all the screws and made sure everything was in place, checked the gear mesh and just about everything else.
i just went and learned how to take it apart and service different parts, i do it with all my vehicles. i changed out the shock oil, checked the gear mesh, the clutch, brakes, oiled the barrings. the one thing i need to do is to find a different way to run the gas line, the metal gears are rubbing against it and are a little more than half way through the line. i plan on using some shrink wrap in that area of the gas line.
use a zip tie and zip tie it to the handle in the center of the car
scratch that, i think there is a different tank that has the fuel outlet that comes out to the side instead of straight out the back.
or maybe get some ofna fuel line clips .
they are plastic and used to run two fuel tubes together, kinda like spark plug wire clips that are used to straighten the wires on your car
http://www3.towerhobbies.com/cgi-bin...?&I=LXBL89&P=0
http://www3.towerhobbies.com/cgi-bin...?&I=LXBL90&P=0
Get the primerless racing fuel tank HPI #72525. The fuel line comes out the top of the tank instead of the bottom and it holds more fuel.
