Foam Tyres
Foam Tyres
I'm looking for some good sites to buy foam tyres for my menace gtr .21 like the mugen tyres wider shore on the back..
Anyone know of any would be a great help ? Thanks Tom..
RE: Foam Tyres
The Menace GTR is odd in that it uses a 14mm hex. As I already said..Schumacher make foams that fit or you can buy the adapters from Wolf to enable you to fit 1/8 scale foams. I will also say again that if you fit the 1/8 scale foams you will have to use tyres of the same diameter front and rear because the GTR has no way to adjust the front/rear drive distribution.
So..your choices are:-
http://www.racing-cars.com/pp/Old_Ca...GTR/U6728.html + http://www.racing-cars.com/pp/Old_Ca...GTR/U6729.html
OR
http://www.wolfpackradicals.com/html...cher_adpr.html + 1/8 scale foams..again note that they must be of the same diameter...this will mean either using 1/8 foam front tyres on front and rear OR reducing the diameter of the 1/8 scale rear foams.
OR
