If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 4 of 4
  1. #1
    Join Date
    Apr 2009
    london, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    need help my engine slevee is to tight to go inside block does it need changing?
    need help my engine slevee is to tight to go inside block does it need replacing.Im goin to replcae the piston and slevee but thething is by replacing the slevee will a new one be much easier to slide in the block? Also ive removed the pin that possitions the slevee becausethe top of the pin meleted for some reason but is there any way of putting a new pin inside and how can i replace the slevee pin where can i get a new pin from.
    http://s847.photobucket.com/albums/a...urrent=fff.jpg
    thanks people
    thanks
  2. #2
    Join Date
    Apr 2009
    wichita, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: need help my engine slevee is to tight to go inside block does it need changing?
    i know ill be told dont do this, but its what ever works. go to a shop the has car painting supplies. get some 2000 sand paper. take a magic marker and mark the sleeve, then when you put it in crankcase the mark will be shown where to sand. take it slow.
  3. #3
    Join Date
    Sep 2007
    Cypress, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Put the engine block in oven. I'm not sure the temperature but will expand and will allow sleeve to easily slide in.
  4. #4
    Join Date
    Sep 2007
    Cypress, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Try 250 to 300 degrees for 5-10 min.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
