Dad needs help with engine and break in
MD
Thanks for the great forum. My son and have made our first purchase of a Redcat Shockwave. I have watched all the videos and we are dedicated to doing it right. I have run into a few issues and need advise.
1. I get the vehicle started however when I pull the glow plug igniter off the vehicle shuts off.
2. I have waited a minute and even opened the idle and then pulled off the glow plug ingiter and it still shuts off.
3. I have noticed alot of fuel sputtering from the area of the glow plug while idleing.
I am on phase two of the break in process and obviously need to correct the issue before I can do figure eights and 1/4 throttle.
Thanks again
Thanks again
My Feedback: (10)
IL
RE: Dad needs help with engine and break in
Lean the high speed needle about 1/8 of a turn and the low speed needle about 1/16 of a turn. Motors are usually set really rich from the factory. NOW, leaning those needles will cause the idle to go up a little, so back off the idle accordingly.
MD
Thanks for the help. That fixed the excess fuel in the glow plug area, however it still shuts off when disconnecting the glow plut ignitor. Iwill keep trying. Thanks again.
My Feedback: (10)
IL
There should not be any fuel coming out from the glow plug. Make sure that you have the little copper gasket in place and that the plug with all the screws are tight.
ORIGINAL: Smiff 24
Have you tried a new glo plug ?
Im suprised all that coating of fuel didnt foul it completely.
