If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 9 of 9
  1. #1
    Join Date
    Aug 2012
    Southern, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Need Tuning? How to tune ??? And run 30%!
    First Seal your engine with High-temp RTV, Seal the carb. neck, and the back plate,this will help hold your tune andseal up any air leaks, all engines will have some leaks.plus it will keep your temps low (170-190 ish)next set your needles to stock settings first for the break in (Rich HSN), break in with 20% fuel, 5-6 tanks., after break in, change the glow plug, use a hot plug, (Thunderbolt #3 works best)and getByron fuel GEN2. Get Byron Race3000, or Pro-driver3000 It's 30%, but don't lean out too much! Always watch for that thin trail of Blue smoke!! at full speed, if there's NO smoke than your too lean, richen the HSN 1/8th turn out. after tuning the HSN(high speed needle), start to tune the LSN, you want your throttle to be quick and instant!, but NO Bogging up to get to full throttle., it should rev up quick.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1788912   Click image for larger version.
ID:	1788913   Click image for larger version.
ID:	1788914   Click image for larger version.
  2. #2
    Join Date
    May 2011
    , TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Need Tuning? How to tune ??? And run 30%!
    Can u post some pics on what to seal? I havent sealed mine but ive ran it pretty hard and did the break in. Did i mess up the engine?
  3. #3
    Anthoop's Avatar
    Join Date
    Feb 2007
    Somerset, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: rx7devil210
    Do you have a problem with the engine? Is it running inconsistantly?
    When I die, I want to go in my sleep like my grandfather,not screaming
    like the passengers in his car at the time.
  4. #4
    Join Date
    May 2011
    , TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I think i have an air leak because it idles perfect then jumps up and starts idling high and rolls forward. I figured it might need to be sealed. Hopefully i didnt ruin the engine.
  5. #5
    Anthoop's Avatar
    Join Date
    Feb 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    In general an air leak will cause the idle to be very erractic and the engine will be very difficult to tune.
    I will hazard a guess that this is a tuning issue.
    If the crankcase loads up with fuel it will cause a low idle speed...once this fuel is burnt the idle speed will increase.
  6. #6
    Join Date
    May 2011
    , TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    so what should i do?
  7. #7
    Anthoop's Avatar
    Join Date
    Feb 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You need to establish if you have a tuning issue or an air leak?
  8. #8
    Join Date
    May 2011
    , TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I ran it today an i think its just a tunning issue. But dont you think i should seal the engine up anyway?
  9. #9
    Anthoop's Avatar
    Join Date
    Feb 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ...if it ain't broke don't fix it.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
