Ok need help
Ok need help
ok so i need some help from some smart people. i got a ofna LD3 used and im converting it toCD3
now im going to put a jammin .12 in it and i cant for the life of me find a exhaust manifold/pipefor it so im here for help
RE: Ok need help
You do have a problem, that's a difficult combination.
Header, ok, no probs, you can make any semi circular header work. As for pipes, anything that fits the HPI RS4 evo should do the job (they are also right sided). The trick as always is making sure the pressure nipple is on the topside of the pipe (or at least ont he side in the case of universal pipes, which of course are never very good). I had a look around, but I cound;t find anything particularly good. Maybe look around and see if you can get an actual pipe from an RS4 evo or a spare part replacement.
RE: Ok need help
do you think this would work
header
http://www.ebay.com/itm/150900417156...84.m1423.l2649
or http://www.ebay.com/itm/271030666775...84.m1423.l2649
pipe
http://www.ebay.com/itm/OFNA-LD3-385...item416910c1cc
or http://www.ebay.com/itm/HPI-86907-Al...item4abbd3546e
or http://www3.towerhobbies.com/cgi-bin...?&I=LXPNB9&P=7
imma noob when it comes to pipes and stuff =/
header
pipe
RE: Ok need help
Personally, I'd go with these to get it up and running, and then spend some time researching and waiting to find a really good pipe with the right characteristics. It'll run fine with these cheap items though, trust me. Please note, I confidently BELIEVE that those are what you need, but if you buy them and they don't fit, please don't hold it against me.
RE: Ok need help
i wish they still made this http://www.nitrohouse.com/PipeInline...de_p_4475.html would make my life easy
this is why i hate this kind of thing if i could just see them in person[:@] sigh
