flywheel confusion ???
hello guys,
I have a ntc3 and im putting a os 12tr engine. and I have to convert it over to starter box starting.
so I order the non-pull flywheel.
well heres were im confused...........
the pull start flywheel has a bigger diameter then the non-pull flywheel ?????
why is that??
I would think that I would need the bigger dia. flywheel so I can use my starter box, right ??
why is that??
Yes, if there is an option for a box/pullstart flywheel then I would expect the box flywheel to be a larger diameter......
Put some pictures/links to what you have bought.
The non ps motor mounts are a bit shorter so the motor sits lower in the chassis. You can use the ps motor mounts with the ps flywheel on a starter box but if you try to use the non ps flywheel you have to use non ps mounts.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBMF1
pic..........
left= non-pull flywheel
right=pull flywheel
and ya I picked up.....
non-pull motor mounts
non-pull flywheel
rear exhaust header
duel chamber ft pipe
just so I could put this engine in my ntc3 and use a bump box.
right=pull flywheel
non-pull flywheel
rear exhaust header
here are the links..
non-pull..
http://www3.towerhobbies.com/cgi-bin...&I=LXBMD9&P=OW
pull start flywheel...
http://www3.towerhobbies.com/cgi-bin...&I=LXBME0&P=OW
non-pull dia. 32.76mm
pull start flywheel dia. 37.75mm
non-pull..
Ah right, that would make sense then....the flywheel is used in conjunction with different engine mounts. As Big Alice said, use the small wheel with the low mounts.
when I was screwing with the car it hit me........... duh...
your right about using the smaller flywheel with the smaller mounts.
I was trying different combos and that just seemed to make cents.
thanks guys.
thanks guys.
