RC On Road Nitro Cars Discuss all aspects of on-road nitro rc cars here
Ball Diff Question
Old 07-23-2014, 02:32 PM
OfnaCD3
Default Ball Diff Question
I have had a traxxas 4tec pro for years.I drove it for the first time Saturday.It has as traxxas 2.5 in it. The car is hard to drive straight it wants to go left or right.I have never driven a ball diff. It corners great do ball diffs act different than gear diffs?The car is in mint condition and everything is adjusted correctly. It almost acts like posi traction when I get on it the rear slides out and I spin
Old 09-25-2014, 12:57 PM
jkdv8
jkdv8's Avatar
Most ball diffs are adjustable. These are I know of. You can go from fully locked to fully open. I have a 4-tec as well and what you are describing mine has more recently started doing the same. Try adjusting them. Mine just need to be rebuilt (not pro, no ball diff.) They start unpredictably unloading at high speed giving that squirrelly handling you're describing. Mine however never spun out unless I took the middle belt off. Might wanna check the condition of the middle and front belts. If they are still on there make sure they're not missing teeth and or slipping. There are shims that came with it that fit under the middle pulley if needed.
Old 10-22-2014, 05:18 AM
mitscientist
Default smallest ball diff in the market
what is the smallest (length and diameter) ball diff in the market today ? thanks
