UPGRADES FOR RS4 EVO
Hi i just purchased the HPI Nitro RS4 RTR EVO Kit. It runs well and i am satisfied, but i was wondering what the best availible upgrades and modifications are.
RE: UPGRADES FOR RS4 EVO
first u can start off with a new air filter get a motor saver, get after run oil, get a new pipe ths is what i recommend, and then u can up grade to a new engine
THS sells nice pipes for the evo, and at a very good price. You can find them at www.towerhobbies.com
spur gears, pinion gears, adjustable turnbuckles, threded shocks, carbon fiber shock towers and upper deck, sway bars, lightened flywheel, shock springs, primerless gas tank, tires,
the list goes on and on... they make so much for this car i love it
CO
OK, the very first thing I would do is buy a primerless tank, or seal up the primer you do have. I was constantly trying to tune the engine at first, it wouldn't run correctly because of air leaks.
The second thing I would get would be the air filter and tuned pipe. I have the HPI High-Performance filter and the THS pipe. Drill new spring holes for the THS pipe so the stinger faces straight out. And try to customize the air filter attachment to get it out of the way of the cooling head. Thats my on my to-do list.l
