THIS IS PROBABLY A STUPID PROBLEM BUT IM SORT OF NEW
Banned
My Feedback: (7)
TX
I have a duratrax street force, the car idles but when it does it moves forward and it only stops when i hit the brake, its not the servo setup beacause i checked it, please help me to make my car stop moving. I ALREADY HAVE THE THROTTLE TRIM TURNED ALL THE WAY DOWN AND IT STILL MOVES FORWARD. any suggestions or ideas will help, thanks josh
RE: THIS IS PROBABLY A STUPID PROBLEM BUT IM SORT OF NEW
there is a idle screw you can lower the idle speed with. Turn it counterclockwise to lower the speed. Dont go too far though because it will stall out when you hit the breaks. You want the idle to be as low as possible but still running good.
Later
Later
