RC On Road Nitro Cars Discuss all aspects of on-road nitro rc cars here
engine cooling
Reply
Old 05-15-2005, 04:01 PM
adam_s_101
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default engine cooling
What are the different ways that you guys keep your engines cool. I find that when i run with the case on the engine can get quite hot
adam_s_101 is offline
Old 05-15-2005, 04:17 PM
snowbl!nd
snowbl!nd's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: engine cooling
Ventilation holes in the shell. One in the front, one in the rear (both about 2in diameter) which are on the same side as the engine - you want to be able to see all the way through the front hole, past the cooling fins on the engine and back out the rear hole. This will allow the air to pass easily through the car when it is moving. You might also want to cut out a side window as this should allow you to acess the pullstart without removing the shell. Oh, and if you want to be able to start the engine without removing the shell cut a small hole directly above the glow plug, which is just big enough for the glow starter to fit through.
snowbl!nd is offline
Old 05-15-2005, 06:58 PM
Josh222
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
and run it a little on the rich, not that it will eat up power but keep it nice and coll , like in the 220F range but not below 200F, being to cold is just as bad as to hot
Josh222 is offline
Old 05-15-2005, 07:09 PM
HPIracer4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i cut the front window and back window out of my shell, seems to work, other than that theres not much else u can do except tuning
HPIracer4 is offline
Old 05-16-2005, 01:57 AM
adam_s_101
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks, i think i will cut out the front and back window, that should keep a nice airflow across the engine
Old 05-17-2005, 08:34 AM
Philster
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Keep the engine clean. I find that even a light amount of dirt or grime can cost anywhere from 10-25 degrees farenheit.
Philster is offline
Old 05-17-2005, 12:52 PM
adam_s_101
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
oh, thats interesting thanks. dirt is not somthing i have ever considered
