tires for ntc3
NJ
tires for ntc3
I just ride the car in the street. When I drive it, it doesnt get any traction and it just spins out all the time. Can someone tell me what tires and rims should I get for my ntc3plus and from where? thanks
KY
RE: tires for ntc3
I use HPI belted x-patterns using HPI green inserts (foams).
http://www2.towerhobbies.com/cgi-bin...&I=LXM979&P=ML
http://www2.towerhobbies.com/cgi-bin...&I=LXNV46&P=ML
RE: tires for ntc3
Make sure your car is setup like the manual says, If it is and you still have the problem you might try setting your front toe-in at 0 degrees (this reduces front steering and helps even things out) and your rear camber at 1 or 0 degrees (this adds more rear traction). Between better tires and these setup it should get you most of the way there.
My advice is get the AE NTC3 [link=http://store6.esellerate.net/store/catalog.aspx?s=STR313706835&pc=]NTC3 Complete Setup Guide[/link] I use mine quite frequently.
Some good sites for reference:
[link=http://users.pandora.be/elvo/]Touring Car Setup Guide[/link] (good basic info and descriptions)
[link=http://www.nitrorc.com/]Nitro RC[/link] (the best tire guide on the net.)
[link=http://ebiz.netopia.com/competitionx/home/]Competition X[/link] (mostly a hopup parts provider but they have some setup sheets online)
RE: tires for ntc3
well i found a problem, dont think it has much to do with traction but the thing that goes from teh servo to the hub carrier is slightly bent i think its called a tie rod? made car pull to that side
RE: tires for ntc3
All I use are Jaco foam tires. I have a pair of rubbers which are absolutly terrible... I use them for drifting. I dont plan on buying rubber tires in the future, foam tires are the way to go. I have used Ellegis and Jacos and they are both great!
KY
RE: tires for ntc3
What color or shore jaco's do you run? I have run the blue sedans and they tend to wear fast on our asphalt surface.
I recently bought the x-patterns again to try them out.
[img=http://img276.echo.cx/img276/989/10093669tz.th.jpg]
