Suspension Arms
NY
Suspension Arms
What can be done so the end of the suspension arms front and back would not touch the inside of the wheel. I have this problem my wheels are hitting the end of the suspension arms where there are pins connected into it, so now my wheels has this black circle around it and its grinding........ help
NJ
RE: Suspension Arms
can u adjust end points and steering travel on ur radio? if u can adjust the percent to be lower or the end points lower. seems as though ur wheels are oversteering so much that its touching the a arm. also how are ur front wheels aligned? straight or toed out a bit? how are the all the other steering settings? what car do u have btw
NJ
RE: Suspension Arms
what sized wheels do u have the stock size or bigger and what wheels do u have as well. ur wheels camber could be set to much in one direction. those are the only reasons i could think of that happening
PA
RE: Suspension Arms
I have the same problem with my rs4 1 with alu. arms, all I did was grind out a slight amout of the inside wheel and now the wheel doesent grind on the arm.
CA
RE: Suspension Arms
I think you need to adjust your endpoints. Because that should not be hapening. If not put like one or two shims on. Make sure your hex hubs are tight and your wheels are on tight.
