will this work in a rs4 3
FL
i found this at tower today while looking through some parts
http://www2.towerhobbies.com/cgi-bin...?&I=LXBM70&P=V
it has 13 teeth
NOW i have the HPI pinion now on my 1st gear and it has 17 teeth (yellow pinion) and thats the lowest HPI makes!!
will this 13 tooth OFNA fit on a rs4 3 clutchbell?
if so since HPI doesnt have a pinion chart w/ that low of a teeth, wonder what would be a good 2nd gear pinion I could use from OFNA AND what spurs would I use??
right now im using a 17T (yellow pinion) on my 1st gear, and a 22T (purple pinion) on my 2nd gear
and Im using 47 at my 1st spur gear, and 43 as my 2nd spur gear
can someone help me out w/ this!!!
it has 13 teeth
ON, CANADA
RE: will this work in a rs4 3
trust me you don't want to go that low, i have a .12r xs in my type ss and i ran gold pinions and all i would do is spin my foam tires, if you go that low you will have no top end but if you still want to yes it should fit but you will need a 17th pinon for second gear because there is a 4tooth difference between them
