Smartech 2 speed conversion
ON, CANADA
Hi, I want to make my single speed smartech into a 2 speed, I know some people have done it and i was wondering what you need to do it, I know i need the 2 speed clutch and the tranny, but do I need shorter driveshafts or is the tranny still the same size?
ON, CANADA
RE: Smartech 2 speed conversion
Honestly I do not see the point in doing this. For less cost you can still get the extra speed and not have to worry about the modifications needed to get the 2-speed to fit. I went up to an 18 tooth clutchbell and 3.75" dia wheels and this thing flys. I have had it radared (with witnesses) at 60.1 mph and there was still some throttle left. I ran out of space so I had to slow it down. I am sure I could have hit 65. that's with the 15CX the car came with. I did do some mods to the engine but it's still the same engine that some many people have said is total junk.
JUNK DON'T DO 60!!!!!!
Enjoymentboy
Enjoymentboy
ON, CANADA
ORIGINAL: NitroRunner
http://www.rcuniverse.com/forum/m_22...39/key_/tm.htm
ON, CANADA
Nope...I used a stock OFNA 18 tooth CB and it worked perfectly. I have at least a gallon on it right now and NO troubles at all. The only real problem I have faced is getting the pipe and manifold to fit in properly once I went to the larger wheels. Accelleration is still strong and if I go from dead stop to WOT I just spin the wheels. I have tried a 21 tooth CB as well and it was just too fast for me. I saw no need to go THAT fast so I backed it down to the 18 and left it there.
Enjoymentboy
Enjoymentboy
