stock rs4 3
stock rs4 3
i got a stock rtr rs4 3 and havent used it in while. im lookin to replace the engine, put a 2 speed tran in, a new pipe and new radio. i know wat 2 speed to get and ive got an engine in mind (HPI Nitro Star Pro .12R XS) but have no clue about wat pipe to get and wat i need to upgrade the radio. any other suggestions bout engines wuld be helpful to. thnx
p.s. - i also have bout 300 to spend and dont want a new car cause i wanna learn and get experience with this one
ON, CANADA
RE: stock rs4 3
I have the .12R XS and is very nice engine, also if you have the money get the wolf pack radicals 2speed it is much nicer, and the mx3 radio looks great, RDlogics makes good 1 piece exhausts so if you get the .12r xs get one of those
FL
RE: stock rs4 3
ORIGINAL: Co0cHi3
there is nuttin i need to upgrade on the car to change the radio? and wat do i need wen i get the 2speed or is that it?
if you want to buy just a transmitter from somewhere make sure its on the same frequency as your receiver you have now, make sure is the same AM OR FM you have now as your receiver and you will need to make sure your on the same channel so get matching crystals which you should have seeing as you have a radio system now
as far as the 2 speed if you buy this one = http://www2.towerhobbies.com/cgi-bin...FVSEARCH=86038
it comes w/ the clutch bell and pinion gears EVERYTHING you need to put your 2 speed on your car!
ON, CANADA
RE: stock rs4 3
If you have the money get the WolfPack Radicals speed, it is a much better unit but the hpi one is good enough[8D]
It is 78 for the complete wolf pack 2speed
http://www.wolfpackradicals.com/html/shaft_2_speed.html
FL
RE: stock rs4 3
i was about to buy that too but its almost double of what hpi sells theirs for PLUS the hpi comes w/ the cluchbell and pinion gears
the W.P. doesnt!
so if you dont have the clutchbell etc. youre looking at $100 just for a 2 speed [:@]
\double meaning once you buy the clutchbell and pinions
the W.P. doesnt!
ON, CANADA
RE: stock rs4 3
yes but the wolf pack one will give you consistant shifts and can handle high power high rpm engine with out the shift point being all over the palce like with my ss but the hpi is still good and if you don't plan racing your fine
RE: stock rs4 3
it came out to 350 for HPI Nitro Star Pro .12R XS, HPI 2-Speed Transmission Nitro 3, Hitec Aggressor SRX 3-Channel FM/1 HS-311 Servo 75MHz, THS Racing Tuned Pipe Set HPI RTR-3, 2 thread lock tubes, and batteries. good price and setup?
ON, CANADA
RE: stock rs4 3
last thing you need is this manifold and i hope you have a starter box[&:] you can't use the ths pipe on the xs it is a rear exhaust engine
http://www2.towerhobbies.com/cgi-bin...?&I=LXFAZ8&P=7
FL
RE: stock rs4 3
ORIGINAL: Josh222
you got me scratching my head now
how come you said a THS pipe wont fit on a rear exhaust engine
my Rossi .12 is a rear exhaust engine and I have a THS pipe???
FL
RE: stock rs4 3
ORIGINAL: Josh222
I was looking at your gallery and you not using the manifold that came with your pipe
the reason why i dont have that header is because I bought this pipe around 2 yrs ago and it was fairly new then and only came w/ a side mount header
MAN I WISH THEY HAD THAT BACK THEN, ive been looking for a header like that FOREVER, but I could NEVER find a header that attached to the pipe using springs
I only found headers that would attach to the engines exhaust port using a spring but then would attact to the pipe using a coupler [:@]!!!
RE: stock rs4 3
anyone know where i can get a rear exhaust header like that for my gt i have the full system from rdlogics but my header cracked i need a new one but i dont wanna spend 50 on a whole new system
RE: stock rs4 3
so that exhaust wouldnt fit witout that manifold or the one i linked fits? if it dont wats another good pipe?
http://www2.towerhobbies.com/cgi-bin...?&I=LXCPX2&P=0
ON, CANADA
RE: stock rs4 3
that exhaust won't work with that engine, you can get the manifold and just a plain pipe or you could go to www.rdlogics.com and buy one of there pipes, there very good
FL
RE: stock rs4 3
ORIGINAL: Co0cHi3
BUT that link you have above for the THS pipe is for the wrong side of the car, its for the DRIVERS side of the car, you DONT want that side pipe for a RS4 3, in a RS4 3 the engine is on mounted on the PASSENGER side so you want a pipe that can be mounted on the passenger side!! If you look carefully at that pipe in your link you wouldve had to turn it upside down to fit in your RS4 3 and the pressure nipple would be on the bottom
heres EXACTLY what you will need for a THS pipe to fit in your RS4 3:
THE THS PIPE: http://www2.towerhobbies.com/cgi-bin...?&I=LXCPX4&P=7
THE HPI REAR HEADER: http://www2.towerhobbies.com/cgi-bin...?&I=LXFAZ8&P=7
NOW that will 100% fit on your car, because I have that same THS pipe in my RS4 3 SS and it fits, just to show, heres a pic of my THS PIPE on my engine
YOURE ALL SET NOW!!
ON, CANADA
RE: stock rs4 3
You would just be better off getting this pipe, it is like 5 bucks more and is specialy made for rear exhaust[8D] http://www.rdlogics.com/cgi-bin/cate...35R&type=store
