right rear wheel sometimes doesnt spin???
FL
when i was messing w/ my car today I noticed that sometimes the drive side wheel wont spin even though the passenger wheel will
it didnt happen all the time, just sometimes...what would cause that
i looked at my rear diff gears they seem ok, no missing teeth or stripped??
any suggestions
any suggestions
ON, CANADA
RE: right rear wheel sometimes doesnt spin???
are you talking when you hold the car up in the air and turn one of the front wheels? the stock hpi diffs are very loose and will do that with out any springs in there
FL
well yes and no
i was holding it in the air turning the wheels
BUT i wasnt turning the front I was turning the rear passenger wheel and the driver sometimes wouldnt turn w/ it but sometimes it would???
FL
ORIGINAL: Josh222
when it woesn't turning where the front wheels turning?
FL
ORIGINAL: J_D
hold onto the other wheel then see if it turns
but when I let go of the passenger wheel the driver wheel wont turn w/ it?? but like I said its weird it doesnt happen all of the time just sometimes??
NJ
Check for loose or missing pins or other things in the drivetrain. Is this shaft of belt driven car??? So the drivers side rear wheel isnt moving at all?? Is this while driving it or turning it by hand...and have u tried driving it yet with this problem?
FL
ORIGINAL: SqueedilySpooch
the driver side doesnt move sometimes but its not like it stuck in place, itll still move if the car moves, its not dragging or anything like that
its weird sometimes it will move with the passenger sometimes it wont...if funny!!??
It drives FINE, I was just taking apart my car today to clean and i noticed when I had the car in the air that the driver side rear tire SOMETIMES wouldnt move when the passenger rear wheel would move, it justs confusing because the rear is linked together so shouldnt the driver move w/ the passenger too?
but its NOT causing any problems w/ the car, I just never noticed it before
MA
i know what is wrong
your missing the pin that attaches the drive nut to the axle
take the nut of and if there isnt a small pin going through the axle that is your problem
it happend to me when i tested my car without the wheels on it, (dont do that)
just take a 5d nail and cut it to size and it should fit and work fine
FL
ORIGINAL: LaMaR828
i dont think its a problem? i guess I just never noticed it before
it runs fine, no problems plus like I said it doesnt happen ALL of the time...so its not the wheel is locked in place or stuck and im forcing it to turn, it turns freely
but anyway thanks for the reply though!!
FL
you know what...I think I mis-understood you
you meant my pin by the upright, that axle LOLOL??
sorry...yeah I checked that too..the pins still there
NJ
did u try moving both rears in the same direction and see if it goes easily...then try moving them in opposing directions see if there is an awkwardness or something...
FL
yes both wheels move in the same direction easy, and when I go in oppisite directions there is no grinding or hesitation or binding up
BUT its funny I did the same thing on the front, I had the same results as I did w/ the rear but i noticed out of all of the wheels my back passenger felt lighter or soemthing when I would turn it, it weird to explain...and the passenger isnt even the one im having problems w/
oh well ~
NJ
....thats really weird...i guess the only thing to do is check the hub carriers pivot balls suspension and everything else aorund that area...maybe u could swap the rear tires with one another and see if it is the wheel itself.
FL
Hey SqueedilySpooch
OK I took apart the whole rear end and inspected EVERYTHING
everything seemed ok
BUT when i go to put the tire on BINGO that did it, I had the wheel nut off and it spun fine but when I tightened the wheel nut IT stopped turning! and felt heavier!
when I put the tire loose it spun w/ the other wheel fine BUT when I tighten the wheel nut it did spin w/ the tire again
Its weird I tighten it just the same as I do ALL of my tires....so I loosened the wheel nut and it spun w/ the tire BUT now the wheel nuts not on tight enough so im afraid im going to loose the wheel now when I drive it?????
do you think the bearing is getting pinched when I tighten the wheel nut???
i figured out where the problem is but I dont know WHAT is causing it?
thanks for any help!!
