OFNA starter box wiring help!
FL
I have a OFNA starter box (10253) w/ the power panel..Im using a 12V gell cell battery
and I need some help wiring it up
can someone tell me how to wire the thing up
I checked OFNA's site but no luck
Thanks!
Thanks!
ON, CANADA
RE: OFNA starter box wiring help!
for get about the power panel for now and just do this because i know it will work.....
from battery to pressure switch to on/off switch to motor and back to battery
FL
does anyone here use a OFNA starter box (10253) and have a rs4 3 car
I need help w/ setting up the pegs and the wheel on this box, my old starter box worked ok but wasnt powerful enough so I got this one and this starter box is WIDER than my other box so its a little different setting up the pegs because my chassis doesnt want to fit cuz its so wide...so I need some help w/ this!
FL
Ok Josh222 I just tried your diagram on some leds and it worked
I didnt want to try it w/ my starter box first, id rather fry some leds than a starter box
wired my starter box up and it works...YES!! [8D]
THX MAN!!! [sm=thumbup.gif]
NOW if you can just help me 1 LAST TIME..I SWEAR!
I need to know how you got your starter wheel set up and your pegs...
When I mount the wheel the LONG length of the starter box my wheels arent wide enough to hang OVER the lid so they stay on top of the lid and its about a 1/2 raised up and the pegs dont even touch my chassis so the starter wheel isnt close to my flywheel
When I mount the wheel the SMALL width of the starter box my tires are good and BUT then its the peg locations...1 side of my chassis has the peg holes close BUT the other side of my car...well THERES ISNT ANY PEG HOLES CLOSE..the closest peg is like 4" away NO WHERE NEAR my chassis???
I dont know how you did yours, but PLEASE help me out, Im itching to run my car!!!!
check out my diagram below
THX!!
THX!!
