weird thing happening
i have a t-15 and hpi rs4 rtr 3 and when i press full throttle, while the car is off, and return it to neutral, it seems that the opening in the carb is less. And when i press full brake, and return it to neutral, the opening gets a tiny tiny bit bigger. But both of these instances i have tried when the car is running, and noticed a rpm difference. Also, how can i make it so the wheels dont spin at neutral, it really bothers me. Thanks
My Feedback: (10)
IL
RE: weird thing happening
that is most likely a servo problem.....get a better servo, adn the "running at neutral" thing can be adjusted by centering the servo arm on the throtle and then leaning toward the brake more
FL
Its just becuase those servoes are absolute junk. i put in a cheap towerhobbies servo i had laying around it fixed the problem.
Also antoher raido related problem with this car that i had was the steering trim. IT would never ever stay straight, i put in a Futaba 2PH, its a great simple radio and it only cost like $60 (it comes with a reciever, 2 servoes, the crystals, on-off switch, and even a reciever AA pack holder) You should seriously get this radio, its great investment considering how terrible the stock radio is.
ORIGINAL: Rs43EVOman
I got rid of my stock servo's and got a pair of stock higher TQ Savage servo's for 20$ that works wonders
