MTx3 vx MTx3 Pro Spec?
RE: MTx3 vx MTx3 Pro Spec?
PROSPEC STANDARD PARTS
T0142 Al. Wheel Hub
T0143 Rear Anti-Roll BarƒÓ2.5mm
T0245 Front Universal Joint Set
T0248 Titanium Middle Shaft
T0249 Rear Universal Joint Set
T0252 1st. Gear 59T 0.8M
T0252 2nd. Gear 53T 0.8M
T0407 4mm Chassis
T0717 Al. Engine Mount
T0715 1st. Gear 21T 0.8M
T0720 2nd. Gear 27T 0.8M
T0804 Titanium Steering Rod
T0805 Fuel Tank (w/H0864 new tank cap)
H0187/1 Titanium King Pin Ball (8pcs.)
H0359 Teflon Brake Pad
H0369 Ventilated Brake Disk
H0533 Front Damper Spring Blue ƒÓ1.8mm
H0534 Rear Damper Spring Blue ƒÓ1.8mm
H0765 Clutch Shoe (Gray)
H0766 Light Weight Centrifugal Shoe
H0767 Clutch Spring (S. Hard)
H0863 Titanium Turn Buckle Rod 22mm (3pcs.)
B0413 Color Silicone Pipe (Gray)
P0413 Carrying Bag
T0142 Al. Wheel Hub
T0407 4mm Chassis
P0413 Carrying Bag
