Tamiya TG10 Mk1 2Speed transmission, HELP!!!
1 Post
hi
i have a tamiya TG10 mk1 (planning to get a mugen MTX4 soon though!) and i i cant seem to get the 2 speed tranny to change. i hav ajusted it and ajusted it and ajusted it and it still wont change! duz any1 no wot cud be wrong with it?
1 Post
RE: Tamiya TG10 Mk1 2Speed transmission, HELP!!!
Check that the shifter mechanism itself hasn't worn down or become jammed.
Basically just take the thing apart, check it and put it back together. If it still doesn't work you've missed something.
1 Post
thanks for the help guys but i have taken it apart, put it back to standard settings, ajusted it slightly each time and i still cant get it to change i have checked the manual and i havent missed anything out.
Rushmorepdf (05-04-2020)
1 Post
yes, the engine is tuned properly! and i have taked it apart, cleaned it and reassembled it again and it still will not work. i dno what to do
1 Post
Hit it with a hammer maybe?
The grub screw which secures the 2-speed hub onto the shaft will loosen itself (preventing the car from shifting) if it isn't threadlocked. Also if the shift point is set too early you may not be able to hear it.
1 Post
thanx 4 all ur help
