Team Magic G4S
#51
NJ
RE: Team Magic G4S
How did she do?
ORIGINAL: razzor
Been busy burning the midnight oil.
Finally finished car.
For now I will use my SX12R for the shakedown on the weekend.
Using a Kfactory pipe ,dont know how good they are but they look sweet.
Used Daz'z Brookland setup from 3hobby as base settings for our track.
Cant wait for the weekend.
#52
RE: Team Magic G4S
Rained all weekend ,hoping to do shake down on Saterday.
We have a club meet on Sunday ,so need to run car and hopefully have enough time to dial her in.
Finished my Stratus 3.1 body today.
I usually run a Mazda RX7 or RX8 body as I have a workshop that specialises in Mazda Rotaries but if I need to run with the big boys I better have the right equipment.
#53
NJ
RE: Team Magic G4S
I need to get a sedan body. Which body do you think works best?
ORIGINAL: razzor
#54
NY
RE: Team Magic G4S
Go with the mazda 6 or Dodge stratus 3.1 from protoform. Also Nitro beast a trophy race at floyd bennit is going to happen happen this weekend on sunday. You can pre register frracers.com Here what they did to the track so far but still more changes to come
#55
RE: Team Magic G4S
As far as bodies go ,I was not sure wich one to get ,eventually settled for Stratus 3.1.
the Nemesis looked good but its hard to find out characteristics of bodies.
I have ordered Blitz bodies and a few prepainted ones ,just need to find a forum with details of what different bodies do.
#58
RE: Team Magic G4S
Ran car today ,put about 11 tanks through it.
The car was awesome !!!
Also got my first crash out of the way.
Cant believe how smooth and precise this chassis is ,I usually have to drive hard to get good lap times.
Tomorrow is club day lets see what happens ..... Ive got 2 thumbs up for G4s.
My new Profi PR 12 ran great as well ,has a really good bottom.
#59
NJ
RE: Team Magic G4S
Glad to see it all worked out for you. enjoy it and keep us updated on good setups.
ORIGINAL: razzor
#60
RE: Team Magic G4S
Had a awesome time today racing at our local club.
Car improved as the day went on until a cowboy tboned me in heat3.
In 1st heat I got my fastest lap .7 faster than my personal best ,2nd heat was better by .4 seconds.By the way I won all my heats.
3rd heat I got tangled with the no2 car and had a guy tbone me ,damaged my pipe and got a stop and go penalty but I still managed to take the win.
For final I changed teh pipe to a Kfactory missile pipe which was flat compared to the AxeMotorRossi 2608 pipe.
Qualified 7th in amain my highest as I usually am in B/C mains.
In main I flamed out twice and killed a plug after that I was running ok ,needed more bottom end punch ,finished 5th.
After a good day racing I am over the moon with car ,a few tweeks and all will be good.
I have 5 weeks till the nationals ,so practice makes perfect.
Thanks again to all the guys who are posting and helping us find our groove.
Have to say ,the car is so smooth to drive !!
#61
NJ
RE: Team Magic G4S
Sure sounds like you had a great time. As for me i cant say the same for yesturday. 2nd race of the day i broke the front joint cups. I cut the corner to sharp and hit the turn. I was done for the day.
Hey razzor i have a engine question for you. I noticed when i just drive around the parking lot my engine runs great. Now when i am on the track and come into the pits to fuel up my motor seems really reved up. Is my bottom end to lean or rich?
ORIGINAL: razzor
#63
NJ
RE: Team Magic G4S
Really? I would think the bottom end would be. I tried to richen my LSN and it seemed to help some. I'll have to try it next week.
How was floyed Bennit field?
ORIGINAL: D-Nicest
Your high end is to lean.
#64
RE: Team Magic G4S
It could be a few things,first could be lean bottom end - do pinch test to get an idea.
Secondly could be your idle is set too high and you using a cold plug tahts fouling up, this is a problem I had.
I use Mega 6 Hot Turbo plug.
If you have a hotter plug try it and see if engine idles high for a fair amount of time and then reduce idle to suit.
Also depends on % nitro used ,compression ,outside temp ,humidity etc...
#66
NY
RE: Team Magic G4S
Come to the race at floyed this sunday and I surely help you out with your engine problems. Don't worry about, just bring a variety of glow plugs mostly 6's and sevens
#67
NJ
RE: Team Magic G4S
Maybe thats my problem. I am using RB plug # 5 Hot. Should i try #6 medium or even #5 cold? The engine was running great when the temp was under 80F but as soon as it went over 80F thats when the problem kicked in.
Do you have a address for floyd bennet field. I am trying to get directions on mapquest and cant get it. Maybe even something on the block its on so i can find it.
If i get the car running again by Sunday ill try to come out there.
#68
RE: Team Magic G4S
Good idea to go to a local race meet ,you will have experienced guys to help you sort out problem.
A few pics of our local track.
#69
NY
RE: Team Magic G4S
For this type of weather put in the #6 and anything above 85 or 90 use the 7, for extremyl hot weather like 100 and up go with the 8, the 5 is for times like the winter , or maybe 50 60 degree weather. Check out [link=http://frracers.com]floyed bennit club[/link] for help on how to get there. The field is exit 11s off the belt parkway, continue on doewn the road until you see the turn before the tolls. make the left and go into the parking lot. the track is open so its open every day of the week. as of now you need a personal transponder, but they may have handouts soon. join the floyed bennit field forum.
#70
RE: Team Magic G4S
Looks lik the G4s drivers are doing well at the Nationals.
Have a look at http://hodamotorsport.net/forums/sho...?p=288#post288
#71
NJ
RE: Team Magic G4S
D-nicest i got directions to get to the field. I would say within 2 weeks or so i should go there. Mapquest said it 51 minutes. Not that bad i guess. First i need to get a transponder and get my sedan body ready.
razzor that i cool looking track.
#75
NY
RE: Team Magic G4S
thats whats up, this weekend I'm going out to prospeed rc raceway in Circleville NY, over there they have handout transponders so all you need is money to pay the race fee.[link=http://www.prospeedrcraceway.com]prospeed website[/link]. They are very nice people out there and the track is brand new asphault. I'm also D-NICEST ON FRRACERS.
