.18 CV-RX?
FL
.18 CV-RX?
Im gonna put [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGGP7&P=0]this[/link] Os .18CV-RX into my Rs4 3 EVo. First i need to know if this is the right one? Also can i use the stock flywheel, clutchbell, clutch assembly, and roto start backplate? For the engine too work do i need to buy anything apart from [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXN373&P=M]these[/link] engine mounts?
RE: .18 CV-RX?
what car is it going in? i would suggest the slide carb, but mien bolted right in, same flywheel, clutch, everything, and duratrax makes a roto start for .12-.21 os's on towerhobies somewhere
FL
RE: .18 CV-RX?
Oh sorry forgot about that, its going into an RS4 3 EVO. Will the clutch, clutchbell, flywheel, and roto-start from my old T-15 work with this? and is there anything else i need besides those engine mounts? Also is that the right ersion for the RS4 becuase there are a few different types
RE: .18 CV-RX?
get this one http://www2.towerhobbies.com/cgi-bin...&I=LXGGP6&P=ML an this for the slide carb setup http://www2.towerhobbies.com/cgi-bin...?&I=LXCXF8&P=7 slide carbs are soo much better, yes the flywheel and clutch will work just fine, but i dont think the roto start will, you dont need it anyways since it has a pull start, mine started on the first pull today
FL
RE: .18 CV-RX?
I guess i i cant get the rotostart to fit ill use the pull starter, ive just ahd bad experiences with them, and im so used to the box that I hope it starts up esy with the pull starter
RE: .18 CV-RX?
the main rule of pull starts is just dont pull them out too far, thats it, OS pull starts are quite durable, havent had a problem with mine so far, as long as you dont over prime it then it should start up within the first 3 pulls
ON, CANADA
RE: .18 CV-RX?
No Need.. The Roto Start for the HPI T-15 fits it perfectly.. so just get the HPI rotostart for the .15 - .18 HPI engines and you are good to go!
ORIGINAL: hpi apollo
FL
RE: .18 CV-RX?
I already have the Purple pinion gears (stock) the yellow ones (low-end power) and red ones (top end power). When i put in the OS should ii change the gears or stick with the stock ones?
RE: .18 CV-RX?
