Help Me
FL
Help Me
I have an r40 with a damaged pinion. The problem is the pinion will not unscrew off the clutch bell. Please tell me any tips tricks or ideas you may have to help me.
RE: Help Me
hey bob.
whats the problem?? screw stripped? just to tight?
if its just to tight. try a soldering gun to heat the head of the screw.
if its stripped. try grinding a screwdriver slot in the head of screw.
FL
RE: Help Me
The pinion gear is just to tight to get off. I can't find a way to hold on to the clutchbell to twist the damaged pinion off. I give the heat a try. Thanks
RE: Help Me
put some electric tape around the clutch bell and use
a pair of channel locks to hold the CB while turning the screw out.
try not to squeeze to hard. you might bend the CB. grab the CB right at the end with the channel locks.
you know where you have a less chance of bending.
good luck.
good luck.
NH
RE: Help Me
Put the clutchbell in the vise just tight enough to grab on to it and use a pair of ajustable pliers (The larger ones with a place to hold on the nuts) to remove the pinion. This worked for me with my RS4.
Banned
RE: Help Me
use a towl folded up to grap the cb with a pair of channel locks at the pinion side of the bell as that where the bell is the strongest, use a standard long l handle allen wrench. a soldering iron is good if its been locktighted. especially if red was used.
Timmahh
Timmahh
