Radio Question
Radio Question
I wrecked my car today and i ruined my receiver in the car. Its a futoba. My ques is if i put the traxxas receiver in will the futoba crystal work for it? I want to still be able to use my futoba transmitter.
1 Post
RE: Radio Question
The crystals should work fine, not sure about the reciever though. Theoretically as long as they're on the same freq it should work - so try it and see. It's "Futaba" by the way
RE: Radio Question
Hey J-RO29, Sorry to hear about your crash, Hope your talking about a "FUTABA" radio. If your radio is 27MHz then it might work, because that is what all "TRAXXAS" is. Surface freq. are 27,29,40,41 or 75MHz. And I think 27MHz has about 6 or 7 channels, and they are different colors. I would check into another futaba rx. ....scott
RE: Radio Question
ya i found out the hard way that a futaba transmitter will not work with a traxxas receiver. for some reaseon i only had about 5 ft of range so i thought i would give a heads up to some pll out there that may try the same thing
