MRX3 Novarossi L5 Plug?
MI
Hello, I just bought 3 MRX3's and was wondering which plugs to run. One of them has a novarossi L5. One has a RB V12. The last one has a Novarossi S5 12. Any input would be greatly appreciated. The novas have OS P3's in them now. Not sure which P3's they are (warm, hot, ultra hot). Thanks
CA
RE: MRX3 Novarossi L5 Plug?
i think you mean that you have an MTX3, not an MRX3...
i typically run "medium" plugs in my OS .12 TZ turbo engine, mostly collari turbo plugs...
MI
yes thats what I meant....sorry for the typo. I just ordered a dozen hot and a dozen ultra hot turbo plugs for them. I will be running all cars with novarossi engines instead of the RB. Thanks for the info.
PA
The P3 plug is ultra hot.
I would run hot or ultra hot,none of the novarossi's that I run run near as good on a medium or cold plug vs a hot plug.I also run 20% nitro.
Mike
Mike
CA
oops. forgot to mention that the higher nitro % your fuel, the cooler plug you should ude. hot and ultra hot plugs are fine for 15-20% nitro. anything over 25% and you'd probably like medium to cool plugs. good luck!
CT
What fuel percentage do you stick with? SOme plug ratings are different than others even though both will say "HOT". I run 30% and need to run slightly cooler plugs for best performance. I use Novarossi CTF7 or sometimes 8. In the cooler weather a hotter plug is helpful.
CA
ORIGINAL: Saboteur10573
most maufacturers vary in their actual temperature classifications, i.e. an OS hot plug may run similar to a novarossi medium or a collari medium-hot, but they are much better indicators of plug performance WITHIN thier respective factories (i.e. a Collari hot plug temp is higher than their medium).
I use Byrons 30% with collari medium turbo plugs. it's rare that i have to go hotter.
