Bearing Help
Bearing Help
I was putting on the Front Carbon hub carriers on my TC3+ and one of the bearing has some resistence, but the other has next to none. I put them in the same way. Do u guys have any help or tips on putting the bearings in the hubs??
RE: Bearing Help
Hi,
There is no secret placing the ball bearings to the turn knuckles. Tolerances of the ball bearing won't be high enough to cause a significant bind. Is that ball bearing in good condition? If so, I would consider the bearing hoods on that turn knuckle, Associated ones? If so again, try to check if the outer drive shaft is bent, you can check with the other no binging one.
Regards
Joaquim
Regards
Joaquim
