Air Filter
NC
Air Filter
I was going to order a after market air filter for my 4tec 3.3 today. What do you guys recomend?
Also any other upgrades would be appreciated.
RE: Air Filter
Foam tires, big bore or proline threaded shocks, sway bars, rpm rear shock tower, tuned pipe, i have head the AE upgrade filter is very good and only like 7 dollars.
RE: Air Filter
I wouldn't recommend the graphite rear shock tower. Get the rpm guaranteed against breaking. But a tuned pipe will give you more HP and a little better top end or more bottom end depending on what pipe you get. the motor saver is like 15 bucks but the AE is like 7 and is better.
