is NITRO STAR T-15 ENGINE a good engine? how fast do they go?
RE: is NITRO STAR T-15 ENGINE a good engine? how fast do they go?
obviously you have no idea what you are talking about, the engine itself doesnt go x mph, gearing effects that, they arent known for being that good, but they will do fine for noob driving
so... like for ex. some engines can reach to 70 mph.. what is NITRO STAR T-15 ENGINE top speed??
Don't they come stock on the Super Nitro RS4? If so, i think my SN RS4 did about 45mph when i first got it...
FL
There is no way you could ever say an engines top-speed. Its just simply incorrect, theres literally infinate different gearings your car could have all leading to a different topspeed. As far as the T-15 goes, its a good realible, inexpensive motor. If your looking for a motor cheap, then the T-15 or an OS .12 CV-R's are good engines, but i just checked and according to tower hobbies their discontinued, but if you can find one there good engines as well. They replaced the CV-R with a TG, which i can reccoemnd becuase ive got no expoerience with, but ask around and see if there any good. im a bit skeptical about their ABL lining, I've yet to hear as good thing about it.
ORIGINAL: ailionvspredator
as i originally said, gearing determines speed, if you cant understand that then you really dont need to be involved in RC
ORIGINAL: hpi apollo
undefined
ORIGINAL: sfar785
that was harsh [X(]
undefined
harsh but true RPM and gearing = speed
the correct answer is that the T-15 is not promising a certain speed, if you have a really powerful engine and really low gearing its gunna so really slow, if you have a weak engine and you have it geared for 100mph then its gunna be very slow
u know this engine has 1.2 hp right?? do you think this engine is above than normal ?? my question is, is this engine considered as powerfull , somewhat powerfull or medium?
MA
if that is the speed, what is it then... that's what i want.. wow it's really out of topic now... i just want the correct anwers..
Gearing is also a huge player in your car's acceleration and speed characteristics. Adjusting the ratio between the motor shaft (pinion gears mount there) and the whole driveline (spur gears) can cause your car to be a very quick off-the-line champ or a top speed master, but not both. I'm not the best with that whole thing, but search "gear ratios" and you should find someone who knows what I don't.
There are other factors that affect your car's speed (such as body aerodynamics) but RPM and gearing are very important characteristics. That's why everyone here is correctly stating that the motor alone does not have one predetermined top speed. Due to gearing, in theory a T-15 could be setup to hit some ridiculous high speed, but it would take forever to reach it.
undefined
U know what HPI apollo you are sersously the rudest person here on RCU......instead explaining into more detail u just brush him off like that........
this is why no one on this forum respects you
FL
i DEF agree. I tired to explain it to him, youjust told him to shut up, you make it seem like inexpeierenced epope shouldnt be allowed to ask an incorrect question. Anyone is allowed to ask a question, and if they happen to be wrong in their thinking, then thats what these forums are for to help them out.
ORIGINAL: MiamizFinest
undefined
undefined
i own a rs4 evo with the nitro star t-15 motor. it is no powerhouse. top speed of my evo is about 40 to 45 mph with the stock gearing . they are a inexpensive engine made for hpi rtr cars and trucks. several months ago tower hobbies was selling them for $69.00. now i believe they do not even sell them. the original t-15 that came on my evo new crapped out shortly after break in. hpi sent me a replacement engine due to a manufacturing defect in the 1st one. the new evo's come with .18 engine. i saw one run and it is quite a bit faster than the t-15 evo. for parking lot or street bashing the t-15 would be alright but your not going the fastest car out there.
i am not miamiizfinest
ORIGINAL: Fasterthanspeed
Calm down miami. Hes been trying to help him and he obviously wont listen.
ORIGINAL: IAMKAOS
CT
For the record this engine makes no where near 1.2HP and is just average. It's only so much faster than the older Nitro FE motor. You're better off spending money on the OS .12TG or OS .18cvrx which can both be found under $170. Both motors will be a lot more powerful, the .18especially than that HPI .15.
NY
im missing something, when did i not give an answer...we have clearly established that gearing determines the speed, now what more is there to say, just leave it at that
