15fe engine sleeve location, notch where it go PLEASE HELP??????
on the nitro star 15fe there is a lil notch on the sleeve, i think mine has shifted, what location should be this notch be at?
RE: 15fe engine sleeve location??????
ORIGINAL: MSTSH80
hate to sound dumb, but what pin on the block?
THERE IS NO PIN AT ALL THAT I CAN SEE, ON MY OLD HPI CAR, THE NOTCH LINES UP WITH SHAFT THE ONEWAY BEARING GOES ON, THE CRANK I ASSUME.
RE: 15fe engine sleeve location, notch where it go PLEASE HELP??????
TURN OFF THE DAMN CAPS LOCK PLEASE, IT DOESNT HELP ANYTHING
like i have said in the numerous PM's back to you, get a picture for us since you obviously arent understanding or seeing anything, geez
ORIGINAL: hpi apollo
must you always be a grouch????
FL
ORIGINAL: MiamizFinest
Ok MSTSH80, when you look and see the little notch on the sleeve, the top of the crankcase (the regular metal that surrounds the sleeve should also have a little notch on it. Lien them up. If for some reason your engien doesnt have one, try placing the sleeve so the nothch faces forward (as in the same diretion of the crankshaft, the threaded shaft sticking out the front of your engine where the clutchbell, flywheel, ect attach). your going to ahve to remove your exhaust, and look in. you should see a straight port with minimu amount of the sleeves brass showing.
BIG TIME EDIT!!
I completely missread the post that was posted before mine............i take back what i sayed...........i didnt read the name of who made that comment sorry!!!!
I think rs4evo was reffering to apollo,
anyway this might help, rebuild guide for 15FE [link]http://www.hpiracing.com/walkthroughs/engrebuild.htm[/link]
ORIGINAL: HeLLsGoD
Holy crap i missread that thanks for pointing that out.........i can be a real dummy sometimes!!!
ORIGINAL: HeLLsGoD
btw thanks for posting that rebuilding the 15fe guide, i couldnt remember where i saw that to post it
thanks everybody
i just guessed and guessed right, and apollo im no idiot, there was no mark on my block under the sleve, i matched the exhause port uo, and that was it.
i had my head off and thats what got me into it, my sleeve is very loose, like no pliers were needed to take out, piston roatation alone moved sleve up.......what does this mean?
It means you still have compression on the sleeve that the piston pushes it up, which is a good sign.
FL
i said that because i had received 3 pm's in less than an hour and had already tried to help but wouldnt listen
ORIGINAL: HeLLsGoD
And miamzfinest i didnt see your post .
i wasnt angry, i was a little irked because in the 3 pm's that he sent me he didnt send a pic after he said he didnt see the notch, thats all, but whoever posted the link thanks because i couldnt find it
belive it or not the reson why HPI apollo sayed that was becuase there is litterally 4 or 5 diffrent versions of this engine and they are all called 15FE..... i personally have 6 or 7 of these motors (blown that havent worked in years) and almost no 2 are exactly the same.........i have one BRAND NEW never seen fuel in a body somewhere AND I KNOW 4 SHO its a 15FE and it looks nothing like any of the others!!
either way apollo cant help but be rude anyways but i thought i would clear that up
