help with HPI RS4 Nitro
CA
Just wanted to know if anyone could help me with my problem. I have a HPI RS4 with a .12 Nitro Star engine. When I start the car, I could drive it for about 3 minutes, and then all of a sudden, my engine shuts off. I can open the throttle all the way, but the car just dies after a couple of minutes. I tried opening the throttle a little bit wider, but I am still having the same problem. If anyone can help me, please let me know. Thanks
NY
RE: help with HPI RS4 Nitro
you might have a leak in the fuel lines, so u can try changing it, and that would also happen if you half a crack or hole in your fuel tank, so you should check those
CA
I just changed all of the fuel lines yesterday. I also checked the fuel tank, and that seems to be good also. How can I check if the engine is flooded? I am a noob to R/C cars, so I don't know how to check it.
your problem is in the tuning, here, read this all the way through and then read it again, i wrote it for noobs http://www.rcuniverse.com/forum/m_5517128/tm.htm
