completely messd up needle settings help!!!
Location: Hamnish, LeominsterHerefordshire, UNITED KINGDOM
I was just messin about in somewhat of a daydream!! and I dont no why but i seemed to mess up all the needle setting am I correct 1 of them is meant to be leaft factory??
I am really confused about the 3 if 3 needles
please help
I mean ive had it running great but i still dont understand 100% the theory!!
please help me[&o]
please help
please help me[&o]
RE: completely messd up needle settings help!!!
we need more info,
what car?... What motor?... what does the factory settings say?.... and why are you turning these if you don't know what your doing?..
thunder tiger ts4n .12 engine I dont no the factory settings lmao
and I dont no why I messed with it!!
wb
wb
CA
Follow these steps:
1) Make sure the idle opening in the carb is 1/8 inch by adjusting the stopper screw
2) 1.5 turns out each on low and high speed needles
3) Start it and first focus on high speed
If it bogs at WOT, it's rich. Tighten the high speed needle
If it cuts out at WOT, it's lean. Loosen the high speed needle.
You will want it shooting a slight stream of smoke, so don't go too lean. Also, temp the head to make sure it's not too lean. If a booger sizzles and dances, way too lean.
4) Now focus on the low speed needle.
If it revs higher and higher at idle without you touching it, too lean. Back it out a little.
If it cuts out after producing increasingly more smoke, too rich. Tighten it up.
5) go back to step 3
how is it coming along? i remember when i modded my force .12 with a os carb, a backplate and shimmed it to where the piston almost slapped the plug, i had to start from scrach. i just closed the hs needle then opened 2.5 turns then got the Ls flush then turned it in one turn, then turned the idle so it was open a mm. i got it to at least start up then took it from there untill i got it purring like a kitten. (if kittens sounded like dirt bikes)
just take your time. it will eventually start. OH one big piece of advice; if the engine doesnt kick, before you start adjusting agin see if your batts are good in the igniter! take out the glow plug and put it on the igniter. if it glows red hot it is good. if not, first change the batts, if that doesnt make it glow, change the plug. experimenting on engines kill the plugs.
trust me on this. i have retuned my engine countless times and it ends up only being a dead batt or plug. if the Hs needle is open 2 or more turns or if you prime it you should always get a kickback or a detonation, even if it is out of tune.
ORIGINAL: Suprachrgd82
yes, it will bog if it is too lean also.
a rich ls setting will cause this too, if it likes to bog when ideling, or when you drive it and a few seconds after letting off it wants to die, the ls is too rich. a good rule of thumb; have the hs set so if you lift the car and it has little hesitation and a constant flow of smoke when you punch it that is good, now set the ls so when you pinch the line it speeds up and dies in three seconds, if it revs high and dies in one second richen it up, if it has no effect untill 3+ seconds it is too rich. remember to only move the needle 1/4 turn at a time, some engines are more sensitve than others.
